RS4 Clutch Problems
Old Jun 5, 2007 | 06:46 PM
brendon2k's Avatar
Default RS4 Clutch Problems
A month or two ago I got a lot of work done to my car when one of my K03s went out. One of the things I replaced was the clutch. I chose to upgrade to the RS4 clutch but I am having some problems with it. The first being the pedal feel and travel. For about the bottom 2-3 inches of movement the clutch (near fully depressed) is very stiff, for the rest of the travel it feels similair to my old clutch. The larger problem I am having is I don't think the clutch is fully engauging. Recently I have had the clutch slip a few timeson the freeway under WOT. My car is chipped running about 15-17psi. '
Has anyone had similair issues? Was something not done properly when installing my new clutch? Is there any adjustments I can make to change when the clutch starts to engauge?
Thanks
Old Jun 6, 2007 | 05:05 AM
oooos4's Avatar
Default RE: RS4 Clutch Problems
Did you resurface your flywheel when you got your clutch replaced??? Alot of the time the flywheel need's to be resurfaced... Did you break in your clutch??? I heard it can really mess it up if you don't... Don't know how true it is, but everybody tells me I need to break in my clutch...
Old Jun 6, 2007 | 10:27 AM
brendon2k's Avatar
I think it may be this http://www.audiworld.com/tech/eng86.shtml, the SAC mechanism on the in the pressure plate not being set correctly.
Old Jun 6, 2007 | 11:55 AM
2k S4's Avatar
Did you break in the clutch? You are suppose to drive it nice for a while to get it bedded in. The FW might be heat scorched, or the SAG adjustment is off.
Old Jun 8, 2007 | 08:59 PM
brendon2k's Avatar
ORIGINAL: 2k S4
How long do you have to break it in for? It has probably been about 1500 miles since I got it installed. I am betting at this point it is heat scorched from slipping on the freeway. I think the SAG adjustment is off because of the fact the pedal is hard to depress for the last 1-2 inches of travel.
Old Jun 9, 2007 | 03:41 AM
Baskin 4.2l's Avatar
Brendon,
A rs4 clutch will not hold the power of a high boostingko4 turbo for long. If you are a stage 3 you will need a better clutch.
phila19146
B8 Models
Dec 22, 2010 02:35 PM
pullacowonaski
Mar 27, 2009 12:00 PM
s4raf88
Jun 16, 2007 01:41 PM
SamJamaica
Jun 13, 2005 02:07 AM
