S6 TQ (AAN) -95, totally dead
Hi,
To make a long story short. I found my car with 1,5 dm water inside the coupe. The ECU didn´t respond when I tried to communicate with VAG-COM (409.1). I removed the ECU and it had a marking of the highest point of water level....So i bought aused ECU and got help introducing it according to instructions on Ross-Tech:s site. Running Vag-Com after the flood a errorcode from ABS has come up saying something about a damaged sensor. (Not a big deal, but it freakes me out cause maybe the electrical system has been severly damaged from the shortcirciut.)
When I opened the ECU, I noticed that one connector was badly damaged (a lot worse than any of the rest) and I traced it to the eletrical wire in the chassi. It was white with a brown stripe.
I read on the SJM Autotechnic site about Ignition problems on a S4 and one of the electrical cables that goes to POS is white and brown.
I havent tested yet if it is that cable, but I will as soon as the rain stops pooring down. I fear the worst.
Since my car is totally dead and not just misfiring I cant test a POS by swapping channels. Is there any other way to test or measurethe POS?
Please help.
With best regards.
Niklas
Please help.
With best regards.
Niklas
Just wanted to tell you that I have found the problem. It was a blown fuse........I have checked all the fuses before but - as a fact now, not properly enough.My problem with the ABS still remains, I will measure the sensors today and maybe I can get a closure on this too this week.
MadisonAudi
Sep 19, 2007 10:41 PM
