S8 rotor/pad advise
Old May 20, 2009 | 12:01 PM
S842's Avatar
Default S8 rotor/pad advice
My S8 has 42M miles on it, and since I am disatisfied with the braking performance I have been researching possible rotor/pad upgrades. My current stock brakes are smooth and vibration free, but just do not seem to have as much stopping power as I want. My parameters are: I don't do track days, but I do sometimes drive in a spirited way, where it is safe to do so. I want first brake application performance (one can't very well ask the deer to wait until I have warmed my pads please), so ceramic pads are out. I also do not want noisy brakes.
Currently, I am thinking of either of two alternatives and would appreciate feedback from others that may have more knowledge than I.
1. Stay with a quality solid, vented rotor - Brembo, EBC, Ulltimate Braking are the brands I am thinking of. PowerSlot seems to have its share of detractors and Zimmerman does not seem to be in the same league as the first three.
Use a better pad. The Hawk HPS seems to have many fans, EBC Red and Blue less so.
2. Use a better pad, again, the Hawk HPS, with either drilled, slotted, or both, or dimpled and slotted rotors. Again thinking Brembo, EBC or Ultimate Braking brand rotors.
I have read of the pros and cons such as cracking in drilled rotors, excessive pad wear with drilled/slotted ones - which others say you can avoid by using a high performance pad.
I would appreciate others experience, hopefully including A8/S8 owners. Specifically, if you stayed with stock type rotors, did a change of pad make a significant difference. Secondly, if you changed to a drilled or slotted or dimpled or combination of such, what brand did you use, what pad, and what was the improvement in braking and the affect on pad wear.
ppgoal
Nov 30, 2010 09:00 PM
BMK666
Aug 26, 2007 05:03 PM
JohnnyBravoA4
Oct 31, 2006 09:22 PM
98 audi jake
Apr 22, 2006 03:11 AM
matcher
Mar 13, 2006 08:52 AM
