sticky clutch HELP!!!
Old Mar 4, 2008 | 11:07 PM
typhoonfd's Avatar
Default sticky clutch HELP!!!
What would caules a sticky clutch from under the dash. I feel a grind in the pedal during engage and also during release (at diff spots and diff times). The master cyl and the clutch slave cyl, both have been replaced but I still think it’s the clutch master that has gone bad again. Any other ideas would be great. The stick is not coming from under the car at the trans its def coming from under the hood or under the dash. If you put your hand on the break booster you can feel it when someone engages the clutch.Thanks.
Old Mar 5, 2008 | 11:33 PM
drev500@aol.com's Avatar
Default RE: sticky clutch HELP!!!
could be the linkage
Old Mar 5, 2008 | 11:36 PM
shawncumberland's Avatar
I'm assuming you checked fluid levels?
Old Mar 6, 2008 | 02:22 AM
typhoonfd's Avatar
ORIGINAL: shawncumberland
the level is a tad high but good, that was the first thing i checked i wish it would be that easy lol
Old Mar 7, 2008 | 09:40 AM
typhoonfd's Avatar
bump help...
Old Mar 7, 2008 | 01:04 PM
CamoA6's Avatar
Have you checked the Slave cylinder? make sure it is all the way in and hitting where it needs to? If its crooked or out some it will miss the pad it needs to hit.
wryfly
Mar 10, 2011 03:26 PM
onepoint8tee
Jul 19, 2010 12:35 AM
225tt
Jan 8, 2007 12:17 PM
kextyn
Oct 10, 2005 03:32 AM
