Stuck Blinker?
Old Oct 24, 2008 | 11:04 AM
mrtel's Avatar
Member
Default Stuck Blinker?
Not having a good Friday. 2002 S4.....when I turn my blinker on (left or right) it comes on solid and does not blink. The hazards, however, do work properly. My first thought was a bad bulb but they all appear to be lit. Thoughts?
Old Oct 24, 2008 | 12:28 PM
Scott Long's Avatar
The turn signals use a seperate flasher from the hazards. You probably need a new flasher. Where it's located is anyones guess, but it's cheap to fix.
Old Oct 24, 2008 | 01:01 PM
lilnickx69's Avatar
No its the blinker relay. There is a write up on how to change it. Basically its the peice behind the triangle. It happened to me on both of the audis i had. The part i beleive is about $45 dollars and maybe takes about 5 mins to change.
here is the write up: https://www.audiforums.com/forum/diy-do-yourself-55/replacing-turn-signal-relay-dudley-doright-17621/
im sure why the pictures arent working but im sure if you google turn signal relay and dudley doright youl find some.
hope this helps.
Old Oct 24, 2008 | 01:02 PM
lilnickx69's Avatar
and the hazards and blinkers all use the same relay.
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
sntemp
Apr 6, 2008 03:44 PM
fibersnet
Aug 3, 2007 11:50 PM
mhiest
Jun 16, 2004 08:06 PM
