stumble at idle - no CEL
Old Feb 25, 2012 | 09:43 PM
Compongi's Avatar
Default stumble at idle - no CEL
I've got a 2000 S4 with 115k and every time i stop at a light or just have it idling it will stumble a little around 40 rpm up or down, but i have no CEL or any other indications of problems. ive recently done spark plugs, o2, cleaned the MAF but none of that helped. any ideas?
Old Feb 26, 2012 | 06:51 AM
M5S5's Avatar
Tech Certified
What are you scanning the car with? It might not be able to read pending codes stored. Does Your scanner have misfire detection capabilities? If so look at the misfire data when problem is occurring.
It is best to have a second person for this that can drive while someone else looks at the data.
Old Feb 26, 2012 | 09:28 AM
Compongi's Avatar
I just have a regular obd 2 scanner, I used to have a misfire code but it went away after I replaced a coil pack. I think my battery is getting weak but I don't know if that would cause it
Old Feb 26, 2012 | 01:30 PM
JETSPEED333's Avatar
SoCal Crew Member
check compression, fuel pressure and vacuum
...not the battery
oldrallyfan
Mar 25, 2013 01:04 PM
2DoubleOTDuce
Jun 29, 2010 12:49 PM
MRPLATINUM79
Apr 11, 2010 11:27 AM
mikekey
Dec 13, 2009 04:24 PM
NateTheApe
Feb 10, 2009 12:20 PM
