Top end noise?
Old Feb 16, 2007 | 11:35 PM
DevilS4's Avatar
Default Top end noise?
Ok, the s4 has been away for the winter and a couple mods are being worked on. Didn't start it for a couple weeks because it's in a garage and I was out of town, so I wasn't worried about it. Now it sounds like it has valve tap for the first couple minutes it runs. I thought it might be a one time thing but it has done it for the last three days straight. Any ideas?
Old Feb 16, 2007 | 11:56 PM
2k S4's Avatar
Default RE: Top end noise?
Sounds like the lifters have leaked out their oil. You should be able to just drive it, lightly till they pump back up, but , I would just change the oil, & then run it. You might get the noise for a while, till the lifter pump back up, don't worry about it, & DO NOT drive it hard until it goes away.
Old Feb 17, 2007 | 12:07 AM
DevilS4's Avatar
That's about what I thought is the lifters bled down from sitting, but it has done it for a couple days now. I always let it warm up for a few minutes before driving (after 2 new sets of turbos in a year) and the noise goes away after 3-5 mins. Wonder why they keepbleeding down?
Old Feb 17, 2007 | 08:27 AM
rayveedub's Avatar
dont use lucas stabilizer, its the same as throwing tranny fluid in your engine.....too thick. if your running mobil 1 switch to a synthetic oil like red line, amsoil,liqui moly, ormotul. the problem your having is the exact reason we stopped running mobil one around here. i reccomend the red line. and bump up the weight. true synthetics flow with alot less resistence so its safe to run heavier weights. in my cars i am running red line 5w-40.
Old Feb 17, 2007 | 05:58 PM
GeilKyle2's Avatar
according to bently, "hydraulic lifters checking"
-irregular noise during cranking is normal
-hydraulic lifters cannot be repaired or adjusted. faulty lifters must be replaced.
-start the engine and warm until radiator fan has come on atleast once
-Increase the rpm to 2500 for 2 minutes
-If the irregular valve noise stops and then reoccurs each time the vechile is used in stop and go traffic
-replace the oil check valves
-if the irregular noise does not stop find and locate faulty hydraulic lifter(s)
Old Feb 19, 2007 | 11:23 PM
DevilS4's Avatar
hmmm..... could be wrong weight oil. I'm running 5-30 royal purple full synthetic. Where are the oil check valves located?
Old Feb 20, 2007 | 03:18 PM
GeilKyle2's Avatar
the oil check valves are located behind the cam gear in the cylinder head
Old Feb 20, 2007 | 03:19 PM
GeilKyle2's Avatar
i've never heard of anyone on here replacing oil check valves though, have you?
rahip4567
B8 Models
Nov 13, 2019 04:04 AM
kenman
Sep 12, 2012 02:34 PM
Schlampah
Jan 27, 2011 08:24 PM
tj19855
Dec 31, 2007 03:28 AM
tbrown
Sep 11, 2006 02:47 PM
