TRANNY PROBLEMS
Old May 11, 2007 | 09:01 PM
ADubyaD's Avatar
SoCal Crew Member
Default TRANNY PROBLEMS
I only have issues getting theshifter into 1st and second.
First is the hardest and it is hard to get out of first as well.
Second is hard to get into as well but not as bad to get out of towards neutral
Does not matter if car is moving or not,
Once I push the gear lever into a gear, it engages just fine
Clutch is fully drepressed and i have tried pumping it... nothing
Have aligned shifter
The shifter is a bit harder to get into the 1-2 gear gate from the 3-4 gate then it is to get into the 5-6 gate.
Car has a UUC SS
Suggestions have been: Misailigned shifter... I have aligned it a few times
-Damaged external transmission linkage... strange because only 1-2 gate is affected.
- Damaged or jagged dog teeth on collar gear. If this were the case then would it be this hard to get out of a gear as well?
Any info you can add or questions that would help the diagnosis would be great... I hope I don't need to rebuilt my tranny but it isn't looking too good for me.[&:]
Old May 11, 2007 | 09:26 PM
ADubyaD's Avatar
SoCal Crew Member
Default RE: TRANNY PROBLEMS
Haha I know, I just thought with a more organized thread and show of info more would get done to solve this..... I really just want to drive mein auto!!!1
Old May 11, 2007 | 11:26 PM
Roadhawk's Avatar
I sympathyze - having just gone through clutch problems myself...maybe its the springs in the clutch plate - just like my problem - I had some of your symptoms - but more was just slipping when in gear. Still very hard to get into reverse and sometimes other gears as well...at least now that I have a new one its so much smoother! Good luck...
Old May 11, 2007 | 11:29 PM
ADubyaD's Avatar
SoCal Crew Member
Thanks again for response... I don't think its clutch, as the car does not slip at all when in gear and once i get in gear, the clutch engages well when i release it. ANY OTHER IDEA WELCOME
Old May 12, 2007 | 03:45 PM
TKneedsS4's Avatar
I had same problem with first and second, turned out to be my motor mounts were shot to shizzz, the problem happened for like 2 days and then it went away but a week later i went and got everything replaced and hasnt happened since.
Just my experience and suggestion. dont ask me why only 2 gears would be affected tho o.O
Old May 13, 2007 | 01:38 PM
ADubyaD's Avatar
SoCal Crew Member
My motor/ Tranny mounts are only 8k old. The other day I had to jam it into gear and the shifter went limp. It will now slide into every gear position but will be able to slide all the way back and forth horizontaly. Whatever gear I think i slide it in. it feels like im in a really high one when i start rolling. I had to get it towed because i coudlnt get reverse... I got it to a tranny shop so well see what they think[&o]
Old May 13, 2007 | 01:45 PM
techbod's Avatar
hmmm I get the same problem but not down to gears lol ( you have to think about that one) but back to the problem ( loose linkage ) very common when your driving street rods
Old May 13, 2007 | 09:49 PM
Brandon2000s4's Avatar
Let me know what the tranny shop says because I have the exact same problem
Old May 14, 2007 | 07:40 PM
ADubyaD's Avatar
SoCal Crew Member
I'll let you guys know.. so far nothing has been replaced and they want 300... this is BS, i think ill just take it to a better shop and go straight to a ******* rebuild,,, oh well
Old May 22, 2007 | 11:12 PM
ADubyaD's Avatar
SoCal Crew Member
Okay.. got new external linkage...822 bucks... no difference. Somebody please tell me more about these burrs on the 1st 2nd gear synchros
arb
Apr 10, 2010 10:05 AM
Alesagol
Nov 17, 2007 02:19 PM
FamilyTunedA4
Mar 28, 2007 05:30 AM
MilitantGrunt
Jun 26, 2006 04:58 AM
romansays
Apr 2, 2006 12:47 AM
