Trans Problem
Old Jul 24, 2006 | 10:20 PM
DevilS4's Avatar
Default Trans Problem
My 00 6 spd won't go into reverse. It's not that it grinds or anything going into gear. It simply wont move left past first gear. I checked the linkage at the shifter side and can't see anything wrong. I'm thinking it may be an issue in the linkage down at the tranny but I wanted to get a couple opinions before ripping into it. Anyone have a similar problem??
Old Jul 25, 2006 | 02:49 AM
Mott Power's Avatar
Default RE: Trans Problem
Happens a lot, and with first and second gear, usually you need to get a tranny rebuild.
Old Jul 25, 2006 | 02:59 AM
2k S4's Avatar
Check your engine & trans mounts, if they are deformed to much, it will be hard to get the car in gear.
Old Jul 25, 2006 | 03:38 AM
Hano's Avatar
i had a similar problem. and with the b5 s4's it'll happen. even if you don't have to get your tranny rebuilt now, you should consider doing so. stasis is the best place to do this tranny rebuild. i would think about doing this if i were you.
Old Jul 25, 2006 | 04:02 AM
Mott Power's Avatar
ORIGINAL: 2k S4
mehhh, if it was the mounts wouldn't it all the gears to some extent?
btw, take the pic of your car off your sig, i happen to orgasim every time i see it
<<<<<<<< imola yellow fanboy
Old Jul 25, 2006 | 03:36 PM
Hano's Avatar
that imola is lookin' nice 2k s4. i'm lovin' the rs4 wheels on it. it looks amazing
Old Jul 25, 2006 | 09:53 PM
DevilS4's Avatar
I was kinda fearing the idea of rebuilding the trans, I've put way too much money into the S4 lately and I've been neglecting the other toys. Ah well, i guess I'll have to bite the bullet.
Old Jul 26, 2006 | 03:33 AM
Hano's Avatar
personally, of all your rides, i think the s4 is the best and you should take care of it. and if you did put all that money in, then rebuilding your tranny would definitely be worth it!! make sure you get it done by stasis
Old Jul 26, 2006 | 12:38 PM
masterk's Avatar
Even though you are convinced on the tranny rebuild..I had a similar problem but I couldn't get into any gears with the car on..and no reverse even with teh car off. after an expensive tow, my mechanic starts it up, and nothing was wrong...he said sometimes you get caught in btwn gears when parking...just put it in nuetral, roll it back a few feet...then try again...it should get into reverse no problem..but it sounds like you have a bigger problem than i did...so I'm no help..is uck
Old Jul 26, 2006 | 05:05 PM
Hano's Avatar
haha, it's always good to hear other points of view. no worries masterk
