Turbo kit
Old Aug 14, 2009 | 12:20 PM
hotgue's Avatar
Default Turbo kit
which turbo kit do you guys think is the best bang for the money.
Old Aug 14, 2009 | 01:05 PM
ALBS4B5's Avatar
Default Turbos
http://cgi.ebay.com/ebaymotors/AUDI-...Q5fAccessories
These ones looks pretty good and arent that much. All you have to worry about now is labor.
Old Aug 14, 2009 | 06:33 PM
FonzoB5S4's Avatar
are you looking for the entire build or just the turbos, inlets and gaskets? with just the turbos installed you'll go faster but your turbo lag is ridiculous.
Old Aug 14, 2009 | 06:43 PM
hotgue's Avatar
Im looking for a complete kit, I was looking at the awe tuning package
Old Aug 15, 2009 | 01:08 AM
bigern45's Avatar
intercoolers on ebay.. inlets.. turbos.. clutch.. pressure plate...silicone boot kit... hardware kit for turbos.. downpipes.. custom exhaust.... then fueling and tuning..
Old Aug 18, 2009 | 10:50 PM
hotgue's Avatar
which kit is better AWE or APR?
Old Aug 18, 2009 | 11:11 PM
meatbiscuit's Avatar
They're both overpriced. Just buy a set of K04s + plumbing from someplace like JHM, ECS, VAST, etc...
Then you can pick up a fueling kit, get in touch with 10secS4...he can get you some good injectors. Then do ECU, again, 10secS4 used to have some good prices, not sure if that's still the case.
Old Aug 19, 2009 | 10:22 PM
hotgue's Avatar
I've been told that ko4's are just as prone to blowing as the ko3's, what do guys think and is there any advantage to using rs6 turbos. Im looking for horse power as well as reliability
Old Aug 19, 2009 | 11:17 PM
bigern45's Avatar
well i have RS6 turbos, and i am peaking at about 25 psi of boost, which is well under their max output.. most k04 tunes run about 22 and then taper to 20 or so.. i think jason @ jhm is doing more than that.. but you have to have meth, a friggin exhaust with no restriction.. and then even at 24 psi the k04's taper cause they are running out of breath. i know my car pulls hard and no boost taper at all to redline, theres a guy on here running 32 psi with a built engine.. i have no regrets as far as going RS6's, but i dont know about K04's blowing, heck, i ran the crap outta my APR tuned K03's without a problem. i do know there is more turbo lag with the RS6's.. they come into full boost about 3900 with my setup.. but there at like 14 psi or so around 3000, and im not sure when k04's peak...
Old Aug 20, 2009 | 02:38 PM
hotgue's Avatar
what would you say is an estimated cost on the set up you have and whats the hp.
