Understeering S4
Old Oct 19, 2006 | 04:17 AM
supaS4's Avatar
Default Understeering S4
My 05 S4 seems to understeer quite alot. any driving tips on how to drive quattro as compared to a RWD???
Old Oct 19, 2006 | 05:11 AM
sooks's Avatar
Default RE: Understeering S4
well it will understeer more than a rwd car.. that is given.. do some suspension upgrades particullarly a rear sway bar should get rid of that understeer.
Old Oct 19, 2006 | 03:03 PM
2k S4's Avatar
Well what do you think will happen when you put the engine in-front of the front axle?[:'(]
60f +40r= understeer.
Change the suspension, and put in a larger rear sway bar. It will help.
yes, you have to drive it totally different from a RWD car. Turn in sucks, so take a more
late apex, and pull in hard, the car will stick. Let the AWD pull you out of the corner, get on
the gas sooner. Slower in, much faster out, more speed drop on entry.
Old Oct 19, 2006 | 03:09 PM
Coop's Avatar
i find putting 4-6 psi more in the rear tires helps the rear end come around. or you could try a scandanavian flick if you're darring...
Old Oct 19, 2006 | 06:02 PM
supaS4's Avatar
Aah..i think i just have to reduce my entrry speed....sucks i enjoyed entering bends really quickly(...
any suggestions on the power gains when using an performance filter??should i use pan filter or cone?? the cone filter tended to give me huge flat spots on my power delivery when using it on my golf....comments?
Old Oct 19, 2006 | 06:49 PM
EvilA4's Avatar
Trust me, you will be exiting way faster than an car. If you slow down a tad, enter the turn late, you can basically floor it through the turn.
In like a lamb, out like a lion.
