window issue...any ideas?
Old Jun 26, 2009 | 01:48 PM
audidude89's Avatar
Default window issue...any ideas?
A while back I suddenly ran into an issue with the windows. I can roll down the drivers window, but none of the other work at all. i cant control it with my panel or with the switches on the separate doors. but my drivers window works perfect. any ideas as to whats causing this? because with the blazing temps int he summer, it would be nice to have them down. thanks
Old Jun 26, 2009 | 02:51 PM
copper07's Avatar
Have you checked the fuses?
Old Jun 28, 2009 | 12:11 AM
audidude89's Avatar
I didnt see much sense in checking them because I figured the odds of the fuses for 3 windows going out at the same time was almost impossible. could it be the main switch panel on the driverside door? or possibly a wire short? i have no idea.
Old Jun 28, 2009 | 12:40 AM
bottlecap's Avatar
check the fuse...you just never know. the driver switch might be broken. its a definite possibility since they're all tied in together. on my other car i pulled the hazard switch out and the turn signals wouldnt work anymore...did it happen all of the sudden or has it been one window at a time?
Old Jun 28, 2009 | 10:38 AM
audidude89's Avatar
all three of the other windows went out all at the same time
Old Jun 29, 2009 | 10:35 AM
copper07's Avatar
I would check your fuses then.
Old Jun 29, 2009 | 09:43 PM
audidude89's Avatar
i checked the fuse box on the side of the dash next to the driverside door and didnt find a fuse for any of the windows in that fuse box. where is the fuse box for the windows located?
Old Jun 30, 2009 | 01:45 PM
deephouse's Avatar
Default or
the window relay. or possibly the switch itself (on the driver door).
Do the window switches at the other doors work?
Mr.Gerb1k
Sep 28, 2013 11:00 PM
crazyquik22023
Feb 13, 2012 11:08 PM
ImTheDevil
Aug 2, 2009 04:07 PM
pmkcolorado
Dec 20, 2007 06:32 PM
TKneedsS4
Dec 2, 2007 11:57 PM
