yay more codes!
well after fixing my coolant issue.. 500 miles later get these. Does anyone know what the engine and the other fault codes mean and or how to fix them?
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Saturday,13,October,2012,17:59:07:32551
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06751
Shop #: WSC 63351
VCID: 336BE5CD014A4F80EC7
4 Faults Found:
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-10 - Efficiency Below Threshold - Intermittent
17538 - Fuel Trim; Bank 2 (Mult)
P1130 - 35-10 - System too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-10 - System too Lean - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DR
Component: AG5 01V 2.7l5VT USA 1819
Coding: 00002
Shop #: WSC 63351
VCID: 8001FA01807CA418A15
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04397
Shop #: WSC 12345
VCID: 356FDBD50F3E51B0C23
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
VCID: 2D5FF3B5E76E1970BA3
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06335
VCID: 3A75C8E92620BEC82F1
1 Fault Found:
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 22186
VCID: 2B5BFDADD97A1740A47
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 09144
VCID: 4081BA0140FCE418615
2 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: E0C1DA81603C0418C15
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: E5CFCB957F1E6130323
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00017
Shop #: WSC 22102
VCID: 24491691B4A4D83865D
1 Fault Found:
00-00 - -
End ---------------------------------------------------------------------
and this was a test i did right before..
Saturday,13,October,2012,15:45:24:32551
Coding: 06751
Shop #: WSC 63351
4 Faults Found:
Coding: 00002
Shop #: WSC 63351
Coding: 04397
Shop #: WSC 12345
Coding: 00160
Shop #: WSC 63351
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Coding: 00304
Shop #: WSC 06335
1 Fault Found:
Coding: 02264
Shop #: WSC 22186
Coding: 16232
Shop #: WSC 09144
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 22102
Coding: 06751
Shop #: WSC 63351
4 Faults Found:
Coding: 00002
Shop #: WSC 63351
Coding: 04397
Shop #: WSC 12345
Coding: 00160
Shop #: WSC 63351
Coding: 00304
Shop #: WSC 06335
1 Fault Found:
Coding: 02264
Shop #: WSC 22186
Coding: 16232
Shop #: WSC 09144
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 22102
1 Fault Found:
00-00 - -
Coding: 06751
Shop #: WSC 63351
4 Faults Found:
Coding: 00002
Shop #: WSC 63351
Coding: 04397
Shop #: WSC 12345
Coding: 00160
Shop #: WSC 63351
1 Fault Found:
Coding: 00304
Shop #: WSC 06335
1 Fault Found:
Coding: 02264
Shop #: WSC 22186
Coding: 16232
Shop #: WSC 09144
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00101
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Coding: 00017
Shop #: WSC 22102
Possible Causes:
-Mass Air Flow (MAF) Sensor faulty
-Oxygen Sensor Control faulty
-Oxygen Sensor(s) faulty
-Fuel Injector(s) faulty
Possible Solutions:
-Check Mass Air Flow (MAF) Sensor
-Check Oxygen Sensor Control
-Check Oxygen Sensor(s)
-Check Fuel Injector(s)
most likely the MAF needs to be cleaned or replaced. if that doesnt work try changing out the o2 sensors next. very doubtful its the injectors.
Possible Solutions:
