02 S4 Stage 3 Avant P0741
Purchasing a stage 3 GIAC 02 S4 Avant TIP trans car, GIAC ECU chip and previous Tip chip owner had for last 5 years. Car operates and currently drives, GIAC chip went bad, new stock TCU installed. Code from VAGCOM listed below:
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 BS
Component: AG5 01V 2.7l5VT USA 3132
Coding: 00002
Shop #: WSC 00000
VCID: 7F13D6E37D0AB0E6E2D-515A
1 Fault Found:
17125 - Torque Converter Clutch
P0741 - 35-10 - Stuck OFF / No Power being transferred - Intermittent
I would like to send the TCU for GIAC tip chip install, my question is will the Tip chip clear this code and car operate on stage 3 GIAC ECU tune or am I looking at a trans rebuild with a Level 10 torque converter and solenoid valve body installations? Any thoughts, as this car is very clean and well maintained with all records and built properly. I have room in the budget with this purchase, any ideas on cost? TIA
Coding: 00002
Shop #: WSC 00000
1 Fault Found:
damselndistress
Mar 25, 2008 03:18 PM
pnc090
Aug 2, 2007 10:30 PM
