Audi s4 b5 boost problem
Old Sep 6, 2014 | 10:44 PM
MasTerMaT31's Avatar
Default Audi s4 b5 boost problem
I have an audi a4 complete S4 swap with unitonic stage 2 ecu...thats why the guy who has the swap before me told me....
my problem is when I floor it from 1st gear to the 3rd gear I reach from 12 to 15 psi, and in the 4th gear reach 14-15 psi, and 5th-6th gear reach 18 psi but drop to 16psi
And also when I floor it in 4th-5ft or 6th gear I feel like I have no power
I not sur if its really a stage 2 chip...but its sure im not stock.... I have k&n air filter, bov upgrade, downpipe, cat back , front mount intercooler
Sorry for my english im from quebec, canada....Im a french guy
Old Sep 7, 2014 | 03:08 AM
FonzoB5S4's Avatar
first off do a boost test. you migh just have a few minor boost leaks.
heres a cheap diy:
http://www.awe-tuning.com/media/pdf/...ure_tester.pdf
Old Sep 7, 2014 | 11:44 AM
no boost leak
Old Sep 9, 2014 | 12:05 AM
FonzoB5S4's Avatar
are you throwing any check engine light codes? are you running upgraded diverter valves or did you switch to blow off valves?
Old Sep 13, 2014 | 06:08 PM
finally no missfire code only an intermittend O2 sensor (first of the passenger side), 1 of the ECT defect... with the vagcom I read the request and log boost....depend witch gear is engage, from 16 psi to 20 psi...
Jchockey100
Apr 14, 2013 12:37 PM
JR88
Jun 7, 2012 04:23 PM
Le31504
Sep 9, 2010 05:41 PM
timahh85
Mar 12, 2009 09:23 AM
fastazs4
Nov 24, 2008 05:36 PM
