How hard: Swapping turbos?
Old Nov 17, 2013 | 08:30 AM
synesthesia's Avatar
Default How hard: Swapping turbos?
Came across a B5 S4 with a 1 blown turbo, 1 good. Currently have a B6 and very DIY. Wondering how hard it would be to swap in a pair of direct-replacement turbo's? Maybe some upgraded ones but likely just straight swap.
Not looking for a DD just a project, thanks.
Old Nov 17, 2013 | 08:33 AM
M5S5's Avatar
Tech Certified
Real easy once the engine & transmission are removed.
BTW , do both while you are in there!
Old Nov 17, 2013 | 12:18 PM
So not something to do in a garage with engine and tranny in?
Old Nov 17, 2013 | 03:12 PM
FonzoB5S4's Avatar
engine definitely has to be removed for the turbos to be swapped. it can be removed without the tranny, but its much harder that way. do both while youre in there and the timing belt, main seals, cam seals, clutch and starter/alternator.
this should help:
Car **** Inside
Old Dec 19, 2013 | 09:54 PM
DocRizk's Avatar
i can say from VERY recent experience, that the engine will need to be removed or like i did, you can lower the subframe, but i wouldnt do it this way again!!! need to disconnect the shifter rod, strut towers, all hoses (dont forget the heater core hoses!!!!!), and lower the engine after unbolting the subframe. still leaves VERY little room to work on the turbos and isnt worth doing it that way. just pull the whole thing.
babdmb
B8 Models
Oct 13, 2013 10:55 AM
jhankins84
Jul 31, 2011 02:57 PM
quattroforthewin
Oct 6, 2010 08:51 AM
speedys4
Jan 17, 2010 11:32 AM
david9999
Feb 20, 2005 09:09 AM
