Adios Muchachos
pilot error, from what i can see he had flaps at too high and angle, took off at too high an angle of attack causing a stall along with drag from the flap (cessna 182 rotates at 60knots) and he didnt counter with the rudder to compensate for the crosswind, inexperienced pilot.
ORIGINAL: CLX
F*ck off, Pam12312357
ORIGINAL: SAudi
He had the flaps set to what looked like 20-30 degrees,definitly not the 10 they should have been. Taxied with the yoke in a neutral elevator position,failed to maintain yaw control,and took off in an extreme sideways angle,what he inadertantlydid is actaully a manuver done to lose airspeed,called a slip. By Bringing the body of the plane sideways to the actaul direction of its travel you have a quite effective and huge airbrake the size of the side of the plane,couple that with excess flaps,and a High AOA and you have a stall,or spin that will happen in a spectacular manner.
