Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
2001 allroad air ride question
Old Jul 15, 2012 | 11:43 AM
kazeevil's Avatar
Default 2001 allroad air ride question
Hey guys, my name is Adam and I run a Hotrod and Kustom shop in WV. Don't normally find myself working on Audi's, but a friend of my fiance with very limited finances has a 01 Allroad with an air ride problem and can't afford to take it to the dealer so i am trying to fix it for her as just a favor. She said the drivers front would leak off slowly for a while and then she had a flat tire at the same corner. She had it taken to a tire shop and all was fine. When she picked it up the front suspension was completely flat and the rear completely up. Compressor comes on and runs, but absolutely nothing happens up front either side. Is there any sort of proportioning valve that separates the front system from the back? also, why would the rear be in the up most position at all times. The manual controls on the dash do nothing either, can't even raise or lower the rear with them. Any help would be greatly appreciated. She's a great lady and I'd really like to get her on the road as soon as possible.
Old Sep 18, 2012 | 05:38 PM
frank tauber's Avatar
She has an air leak in the front and probably burned out the compressor
The cheapest way to fix is go to buyautoparts.com she can get the compressor and both front air bags for about $950.00 total the dealer is more than double this
loktek
Nov 30, 2011 10:22 AM
vtraudt
Feb 28, 2011 05:45 PM
dadracer
Aug 19, 2010 10:23 PM
jkimballcook
Jun 5, 2010 09:09 AM
carco
Aug 20, 2006 03:39 AM
