Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Active air gas shock absorber strut repair set
Old Nov 21, 2023 | 06:04 AM
MrChubba's Avatar
Default Active air gas shock absorber strut repair set
Hi All,
I have Fault Code 00143 - Right front dampening adjustment valve. I can buy a "Repair Kit' Part number: 4F0 498 085 and as per the attached pictures. Has anyone got any experience of fitting these and are there any tests that I can do to confirm the part is faulty?
Many thanks in advance
Old Jan 13, 2024 | 01:25 AM
davideidson's Avatar
The fault code 00143 indicates an issue with the right front dampening adjustment valve in your Active Air Gas Shock Absorber. Before replacing, check the wiring for any visible damage or loose connections. Perform a diagnostic scan to ensure the fault persists. If the issue persists, replacing the valve with the repair kit (Part number: 4F0 498 085) is a logical step. After installation, conduct a thorough test drive, paying attention to any abnormal sounds or handling issues. If the problem persists, consult a professional technician or use specialized diagnostic tools for a more in-depth analysis of the suspension system.
truebreakerz
Jan 2, 2013 06:01 PM
morpheous
Apr 29, 2011 11:13 AM
BimmerMan3
May 9, 2010 09:28 PM
ArcticZ
Mar 13, 2010 01:37 PM
mjvss21
Nov 22, 2005 05:23 PM
