Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Braking Upgrades?
Old Feb 11, 2009 | 01:08 AM
Ultrasport Demon's Avatar
Default Braking Upgrades?
Hey,
Just wondering what anyone would recommend for a Brake Upgrade. I don't really want to go with a Big Brake Kit yet... I was thinking about rotors, pads, lines, and fluid. What would be the best bang for the buck... But also add more stopping power than stock?
Old Feb 12, 2009 | 06:20 PM
Any suggestions?
Old Feb 12, 2009 | 07:27 PM
ImTheDevil's Avatar
Hands down, the A8 kit. Uses rotors that are an inch larger (in vented only, or in slotted or drilled/slotted), plus the caliper carriers from the TT. The combo is perfect for street-driven A4s. I love mine (see sig pic - that's my slotted/drilled A8 kit inside 18" wheels) - they look great and work great. Tons of info available in Search (many threads in the past on it) - combine them with a good set of pads (I have Hawk ceramics) and you'll love it. It's become scripture around here - so it is written, so it (should) be done. Read the posts and you won't find a single owner who feels the upgrade isn't worth it.
Old Feb 23, 2009 | 07:33 PM
Emilgevor's Avatar
yeah devil i agree when i saw yours i fell in love with them maybe someday ill get around to do mine too
Old Feb 23, 2009 | 07:52 PM
ImTheDevil's Avatar
You definitely should. Of course the only requirement is that you run at least a 16" wheel (not a problem for most Audis) - the A8 kit won't clear a 15". Emil, when you're around next time, take my car for a braking run up the road. You'll come back and call ECS on the spot
Old Feb 23, 2009 | 08:25 PM
Emilgevor's Avatar
Whats ECS? lol
Old Feb 23, 2009 | 08:28 PM
ImTheDevil's Avatar
www.ecstuning.com - where I got my A8 upgrade.
Old Feb 24, 2009 | 12:43 PM
Khardysius's Avatar
If you are looking into getting some decent lightweight 2 pc rotors try DBA. I was researching for my car, but couldn't find anything. After some investigation I found out that the S4 rotors have the same dimensions, IIRC. Should be easier for you 1.8T/2.7T g
guys.
Didn't do much research on calipers as mine seem to do the trick with good pads and stainless steel lines. Then again, I'm not tracking the car either.
When I can afford it I would like to purchase a set of DBAs (2-pc fronts, and lightweight rears).
**pre-edit -- Looks like DBA has updated their webpage to show the correct rotors for the V8 4.2L.
**post-edit -- Here is the link to the catalogue which shows the replacement part for your Audi - http://www.dba.com.au/2006/PDF_CATAL...e_2009%201.pdf
TheBat
Jul 24, 2009 04:56 PM
Tasteofblood
Jan 4, 2009 09:19 AM
JTM
Mar 25, 2006 02:29 PM
trav802
Feb 26, 2006 11:19 PM
Big Ed
Jan 17, 2005 09:13 PM
