Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Quick Spring/Shock question A6
Old Jun 9, 2011 | 10:08 PM
Turkeybaster115's Avatar
Default Quick Spring/Shock question A6
Hi guys. Does anyone know for sure, if the OEM springs and shocks/struts from a 2007 Audi A6 3.2 quattro, can fit into a 2000 Audi A6 4.2?
Thanks
Old Jun 15, 2011 | 09:48 AM
jmarshall098's Avatar
Because the Audi A6 3.2 Quattro used four links, double wishbone with anti roller bar suspension at the front wheel and independent suspension at the rear wheel, where as Audi A6 4.2 uses independent suspension on both at front as well as at rear. The springs stiffness is designed based on the frequency of vibration and capacity of vibration absorbance, so due to the different vibration absorbing capacity you can not use spring of Audi A6 3.2 Quattro in 2000 Audi A6 4.2.
I hope you would have your answer from the above mentioned reply..
anmagro
Dec 10, 2008 12:02 AM
shortyxc
Sep 18, 2008 09:41 PM
samamainia
Apr 22, 2008 02:33 AM
thetryal
Apr 29, 2007 02:51 AM
TheJazz7
Aug 1, 2006 10:47 PM
