Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Rear drivers side "squeeking" noise after wheel bearing replacement
Old Nov 6, 2009 | 09:06 AM
rykse's Avatar
Default Rear drivers side "squeeking" noise after wheel bearing replacement
I have a 2000 S4, which I bought 6 months ago... It's been a great car thus far and I just replaced the drivers side rear wheel bearing two days ago and now there's a very noticeable "squeeeeek" when I get in the car, turn or go over uneven terrain. It sounds like an old pick-ups suspension. The only thing that I can think that might be making the noise is the upper control arm bushing... Also there is a barely noticeable knock from the same wheel that I can hear when starting and stopping. I'm thinking that this noise is caused from the tie rod. If anyone has any suggestions I would appreciate it!
Old Nov 6, 2009 | 04:36 PM
BS4's Avatar
BS4
I don't know if you DIY the wheel bearing or took it to a shop, but since you just replaced it have you checked to see that everything was tightened back together properly?
Old Nov 6, 2009 | 10:43 PM
ImTheDevil's Avatar
Could easily be the swaybar endlink.
Old Nov 7, 2009 | 04:49 PM
rykse's Avatar
Thanks Devil... it was the swaybar end link.
Old Nov 7, 2009 | 04:55 PM
ImTheDevil's Avatar
You're welcome - glad it was an easy fix
freedomone
Feb 16, 2013 08:04 AM
dbshiznit
B8 Models
Sep 8, 2012 08:43 AM
russo513
Aug 26, 2008 02:11 PM
