Suspension Is your ride slammed to the ground? Did you lift it so high you need a ladder to get in? Step in and let's talk about it.
Which springs will work?
Old Feb 5, 2009 | 01:53 PM
Prizmatik's Avatar
Default Which springs will work?
I have a 1997 1.8T automatic transmission A4. I have seen many lowering springs for sale, but they are from different models, for example, the V6 power plant, all wheel drive, etc. Will any springs made for the B5 A4 work with any model? Or do I need to get a set of springs meant for my front wheel drive 1.8T motor? Thanks for the help.
Old Feb 7, 2009 | 03:00 PM
Pa Matt's Avatar
also would like to know!
Old Mar 1, 2009 | 11:28 PM
ImTheDevil's Avatar
I'm not sure what differentiates a quattro spring from a fwd spring, but there must be something. As for which models to use, stick with 1.8T springs. The 1.8T is lighter than either V6 model (A4 or S4) - the V6 models have stiffer springs. They'll fit on your car, but they'll make the car sit pretty high because of the higher spring rate.
ChuteBoxe360
Apr 12, 2013 06:41 PM
AlexB27
Oct 4, 2012 07:53 PM
88notchblown
Sep 27, 2009 01:34 PM
sineo
Mar 16, 2008 12:11 PM
krnaudi
Mar 30, 2007 04:50 AM
