VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
2001 C5 2.7t Random Loss of power when under pressure. Here is the Vagcom Codes
Old Aug 7, 2012 | 11:57 PM
seanlarrow90's Avatar
Default 2001 C5 2.7t Random Loss of power when under pressure. Here is the Vagcom Codes
I am Losing power in 3rd gear at about 3500rpm only when I am stepping on it. I also lose power random whenever i step on it. Here are the vagcom codes
5 Faults Found:
17865 - Exhaust Gas Temp Sensor 2 (G236)
P1457 - 35-00 - Open or Short to Plus
16815 - Warm Up Catalyst; Bank 2
P0431 - 35-00 - Efficiency Below Threshold
16805 - Warm Up Catalyst; Bank 1
P0421 - 35-00 - Efficiency Below Threshold
16487 - Mass Air Flow Sensor (G70)
P0103 - 35-10 - Signal too High - Intermittent
17963 - Charge Pressure
P1555 - 35-10 - Maximum Limit Exceeded - Intermittent
I have a apr stealth catback and a awe b5 s4 downpipe cut and modified for my C5. I also have a b5 vast performance intake with heat shield. Giac chip
eircheard
Mar 6, 2012 10:31 PM
MartinCieslak1
Mar 1, 2010 11:43 PM
CLX
Nov 20, 2007 05:04 PM
jeanphilippeg
Jun 19, 2007 01:30 PM
