Fault code p1647
Hello all, my first post and am in need of some help. Hopefully I will be able to give some advice in the future in return
So, I bought a audi A6 (c5 2000) estate the other week, with a fault on the dash
The fault is the traction control light is continually lit on the instrument cluster, I purchased a vag.com kit and have read the fault codes.
Abs brakes, 1 fault found
18055 - check coding of ECUs on powertrain data bus
P1647 - 35-00
I spoke to the owners when viewing it first to the husband outside who said he had the problem checked and it's a wheel sensor, then I spoke to his wife who also said they had it checked and the mechanic told them that it'll pass an mot and as they're selling it to leave it? Then she slipped up a little bit and said that the mechanic also said that it'll be a waste of £400 as they were selling it.
I've searched google until my eyes are sore but have found no definite answer but a lot points to the abs/esp module.
So I'm guessing it needs a new abs/esp module from the info I've been given? but in all honestly I'm not sure???
Hopefully someone can give me a nudge in the right direction.
Thanks and any input will be mostly appreciated.
Griff
P1647 - 35-00
Griff
So an update if anyone stumbles accross this problem.
After much searching and many vag com plug ins I managed to figure out that the abs module had lost its coding somehow. I was told the gearbox had been replaced at some point if that would cause a problem?
So it was quite easy. Plug in the vag com and open the program, turn ignition on.
Go to options and test the link, all ok.
Go to abs, coding, change the code from 00032 to 00011 in the soft code box, press do it!
The light on the dash turns off
happy days.
Press exit, exit, exit until the program closes, turn off ignition, unplug vag com lead.
Whilst I was there I turned off the active gearbox setting by going into the transmission button and the same as the abs change the code from 00000 to 00010,
Really happy now and am really enjoying learning about vag com mods.
happy days. Press exit, exit, exit until the program closes, turn off ignition, unplug vag com lead.
Merci,tocmai am aceeasi problema doar ca eu am umblat la multe mufe/conectori de la masina pentru ca aveam un lag la acceleratie.Am ajuns si la suici-ul de la pedala ambreaj l-am demontat pe ala si curatat ,era blocat intr -un fel acolo,agata in ceva si dupa o curatare cu spray de concate l-am remontat si sta aprins tot timpul.Azi cumpar altul nou si sper sa dispara eruarea,asta era o cauza ca nu ma lasa sa pornesc uneori asa din senis. aparea in bord[anomalia ESP], acuma merge masina de rupe fara lag la acceleratie[ asta dupa ce am luat tot cablajul,mufe,sigurante,relee bucata cu bucata la desfacut si curatat.am gasit 2 relee cu problema] ,sunt super incantat.Am citit postarea ta si sper ca dupa ce-i schimb acel contact de sub pedala ambreaj sa nu mai am acel martor in bord.Zi faina!
