VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Key FOB dosent work ive tried every option...I have one fault code if you can help.
Old Mar 3, 2014 | 04:23 PM
bboylawless's Avatar
Exclamation Key FOB dosent work ive tried every option...I have one fault code if you can help.
Here is all the ways ive tried to fix it. And yes ive searched for ways to fix it before posting a new thread.
I dont have two keys to do the Key in door Key in ignition programing I only have one key. When i try to get into Central Conv. to do an adaptation with VagCom i get a "No response from controller". Also ive read elsewhere to put the key in the on position and hit unlock or unlock. That dosent work. Also ive heared put it in the door hit unlock or unlock that dosent work. Ive tried holding the key to the right or the left in the door for a certain amount of time and hitting unlock/lock. Ive tried all the options.
I know my car is getting a signal from the keyFob because when im in 35-Central Locks in Vagcom i forget which measuring block it is but when i press either lock or unock on the Fob the values in the measuring blocks change.
Here is the only fault code i pulled
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump D06
Coding: 16140
Shop #: WSC 06335
1 Fault Found:
01365 - Lock/Unlock Switch: Interior
29-00 - Short to Ground
Old Mar 4, 2014 | 05:14 PM
any advice?
Old Mar 6, 2014 | 02:21 PM
gsjohal's Avatar
If the central locking ecu (35) is seeing the key signal, then this would suggest that it just isn't responding and carrying out the function of locking/unlocking the doors. Have you looked for signs of water ingress around the CDL ecu? Maybe try unplugging and reconnecting it.
Old Mar 7, 2014 | 12:12 PM
i will go check that now and let you know how it goes ..thank you
jonet
Aug 23, 2012 03:35 AM
thanhtung3000
Audi Q7
Apr 10, 2012 12:04 AM
justinclarke
Feb 6, 2008 05:59 PM
justinclarke
Bondga
Jan 31, 2007 01:40 AM
