VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
little yellow symbol - vagcom output
Old Aug 11, 2009 | 07:19 PM
goslings's Avatar
Question little yellow symbol - vagcom output
hi yellow symbol came on VAGCOM tells me
3 Faults Found:
16814 - Catalyst System: Bank 2: Efficiency Below Threshold
P0430 - 001 - Upper Limit Exceeded - Intermittent
16804 - Catalyst System: Bank 1: Efficiency Below Threshold
P0420 - 001 - Upper Limit Exceeded - Intermittent
16414 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit: Malfunction (Open Circuit?)
P0030 - 004 - No Signal/Communication - Intermittent
Is this simply telling me I need new Lambda sensor or something more serious
cheers
Ian
Old Aug 12, 2009 | 11:32 AM
cincyTT's Avatar
I'm make believe
Both o2's are throwing a code. You either have a large exhaust leak at either the head to manifold, manifold to turbo, turbo to downpipe, or a hole in the downpipe like the flex section. If you dont hear a leak, wait till the car is cold, start it and feel for puffs of air with your hands. If you still dont find anything, then your are just unlucky and had both o2's go at the same time
Old Aug 15, 2009 | 05:10 AM
goslings's Avatar
many thanks
I was unlucky both went at the same time and they are very fiddley to fit you need arms with more than two wrists
(no turbo on uk 3.2L V6)
U's Audi
Dec 29, 2012 06:11 PM
Threeputt
May 22, 2008 08:55 AM
hxgaser
Apr 25, 2008 06:54 PM
andrewbb89
Jan 15, 2007 03:17 PM
gilee_8
Nov 28, 2005 02:17 AM
