VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
p0346 camshaft positioning sensor ???
Old 02-02-2016, 12:29 PM
Scottytek23's Avatar
Default p0346 camshaft positioning sensor ???
hey all im new to the audi world iv had my 2001 audi a4 quattro 2.8 ATQ for about a year now and iv recently had a rough idle and a flashing check engine light go off in my car and then eventuallt ended in a no start and just cranks spark and fuel are good ran the codes and it came out to a few different codes listed below
p0130 oxygen sensor circut bank 1 sensor 1
p0170 fuel trim bank1
p0173 fuel trim bank2
p0346 camchaft positioning sensor a circuit range/ performance bank 2
p0300 multiple misfire detected
p0304 cylinder 4 misfire
p0306 cylinder 6 misfire
p0305 cylinder 5 misfire
besides the o2 sensor all the other codes are new, engine shut off about 1 block after the check engine light started flashing then it wouldnt start again
any help with this matter would be appreciated thank you.
camshaft positioning sensor was replaced
Old 05-08-2016, 06:38 AM
ImTheDevil's Avatar
If you've replaced the cam sensor, clear all the codes (they won't auto-clear), and see what comes back. Anything that does is still an issue. And all but the O2 code could easily be caused by a bad cam sensor.
Kelly-4.2
01-21-2011 03:37 PM
jpmiller72
09-19-2010 08:59 AM
twinturbosixer
05-06-2009 07:09 PM
nighta46289
12-11-2006 02:39 PM
ryncombs
01-22-2005 12:48 AM
Quick Reply: p0346 camshaft positioning sensor ???
