VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
USB Vagcom Help. Port Found. Interface not.
Old Jul 31, 2006 | 07:21 PM
mypreludeisred's Avatar
Default USB Vagcom Help. Port Found. Interface not.
Hey
First off this is the cord I bought. ( Click CORD)
I am using shareware version 409.1
When i go to test the cord, which is a must before you can use the program, I get this message.
Port status: OK
Interface: Not Found
What can i do here? Ive tried to find help online but i just cant. No info has proven helpful.
I have reinstalled drivers 3 times. The drivers are from ross-tech.
Any help would be greatly appriciated. I posted in the Ross-tech section of vwVortex. It was literately locked in 3 minutes because it is an "aftermarket" interface and not ross-tech.
frikin ****.
Thanks guys
Old Jul 31, 2006 | 07:25 PM
dafrazi's Avatar
Default RE: USB Vagcom Help. Port Found. Interface not.
You need the driver for that cord. The ROSS-TECH driver want work.
Old Jul 31, 2006 | 07:29 PM
techbod's Avatar
the disc you got is just a copy from the Ross tech site so has no licence (not to say you cant use it though) but its very basic the cable?? well you pays your money and takes you chances and eBay stuff I need say no more
Old Jul 31, 2006 | 07:31 PM
dafrazi's Avatar
I have the same cable. It will work. If you want full functionality of VAG-COM you will need to buy a license. I just use it to read and clear the codes. I borrow a ROSS-TECH cable from another forum member when I need to do more.
Old Jul 31, 2006 | 07:39 PM
Can you, perhaps, send me a copy of the driver you used to install your cable?
Or
Do you know of a location to get the driver for that cord?
Thanks
M
Old Jul 31, 2006 | 07:42 PM
dafrazi's Avatar
The driver came in the box with the cord. I'll see if I can find it when I get home.
The cord uses a COM port emulator. It doesn't work like a true USB device.
Old Jul 31, 2006 | 07:58 PM
Alright thanks.
Yea my little white CD that came with the cord is completely blank and i can write on it if i want to....
Let me know
Old Jul 31, 2006 | 09:30 PM
wolfdog's Avatar
My apologies if you tried this, it took me a couple attemps to figure this out so I'm doing it anyway.
What happened when you "installed the drivers"? I'm going to guess the program copied them to a folder on your computer and that's it. Find out which folder because I think you actually need to install the drivers in Windows. Try this if you haven't:
Connect the PC to the car with the cable
Start-->Control Panel-->"switch to Classic View" if you aren't already (look on the left side of the window)-->System-->Hardware tab-->Device Manager
If the USB cable is appearing there with the yellow exclamation point warning, right click it and select "update driver". You may want to try this anyway even if it isn't.
Don't let windows connect to the internet, just get to the next screen. you want the advanced option to install from a specific location. Click the browse option and navigate the popup window to the folder you "installed the drivers". When you select the folder, click OK and run with it. The test should work after that.
Even if this isn't your problem, it may save someone 5 minutes in the future. I'd like those minutes back...
GL
dafrazi's Avatar
Found it PM me your email address.
StevenX
Dec 16, 2013 10:13 AM
theunknownprince
Apr 16, 2011 10:52 PM
iamaudi.com
B7 Models
Apr 10, 2009 08:19 PM
Jits7
May 12, 2006 12:30 PM
jukeit
May 10, 2005 01:21 PM
