ran vagcom and found problems
Thanks for the help in advance,
I did a full scan and the results :
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 8D0 906 266
Component: 2,8l V6/2V MPI OBD2 D03
Coding: 01051
Shop #: WSC 00000
2 Faults Found:
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 68-00 - Cylinder 1
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 F
Component: AG5 01V 2.8l2V USA D80
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
00526 - Brake Light Switch-F
27-00 - Implausible Signal
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 G
Component: ABS/EDS BOSCH 5 7590
Coding: 0265109001
Shop #: BB 37590
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 F
Component: A4-KLIMAVOLLAUTOMAT_D64
Coding: รถ
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 919 035 G
Component: B5_KOMBIINSTRUMENT D04
Coding: 00262
Shop #: WSC 06311
End -------------------------------------------------------
Any idea on how to fix any of these problems or sugesstions would be much appreciated thanks,
josh
Coding: 01051
Shop #: WSC 00000
2 Faults Found:
Readiness: N/A
Coding: 00000
Shop #: WSC 00000
1 Fault Found:
Coding: 0265109001
Shop #: BB 37590
Coding: รถ
Coding: 00262
Shop #: WSC 06311
josh
the engine wasn't up to normal temp when you did the scan by your read out so many sensors gave out poor readings which would be normal, I recommned you do the test with engine running when the engine is piping hot after a good run
The fuel level sensor error is pretty normal. I did a write up:
https://www.audiforums.com/m_20295/tm.htm
