VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
Vagcom help..
Old May 1, 2008 | 12:48 PM
Ericp501's Avatar
Default RE: Vagcom help..
Not sure what LIFO is.. and lower it to what?
Old May 2, 2008 | 10:21 AM
Ericp501's Avatar
Tried.. still nothing
not sure what LIFO is tho
Old May 2, 2008 | 10:53 AM
hiwords's Avatar
you are installing this on a xp computer right? if you have vista, i think some guy on audizine figured it out
Old May 2, 2008 | 02:01 PM
Ericp501's Avatar
its XP.. I just got my new ecu.. doesn't fit at all.. I need help guys
Old May 2, 2008 | 10:33 PM
chaos92287's Avatar
try messing around with the baud rate. the guy used 9600. if the software is reading the right COM port as what you have that usb drive set up as, it should work
Old May 5, 2008 | 06:26 PM
Ericp501's Avatar
I've tried.. its weird because it reads like 4 channels but wont get the other ones.. My friend scanned it for me before on his shop's program and it was fine.. then I needed it scanned again so I tried to scan it with mine and I could only get it to read 4 channels, so I had my friend hook up his shop's Vag again and his did the same thing.. So I feel like it has something to do with my car
Old May 10, 2008 | 12:11 PM
Ericp501's Avatar
Anyone have an ECU they don't need.. I'll buy it
Old May 10, 2008 | 01:02 PM
  #18
sineo's Avatar
You're not supposed to be able to access every module. There are several in Vag-Com that aren't applicable to every car. I played around on mine at first, but I think I was only able to get into a handful, too...transmission, engine, ABS, central locks, and maybe one or two more. I don't think that the problem you described in the first post is a symptom of the Vag-Com issues you're experiencing.
Old May 13, 2008 | 06:14 PM
  #19
Ericp501's Avatar
most people can get into at least the engine and tranny.. I can only get into my dash. The last time my buddy scanned for me the volts were off and so was the throtle body.. same thing happens and the TB wont set itself when i pull the battery off. I've decided its not vagcom since autospeed's shop vagcom read the same as mine.. It is a problem with my ECU or god forbid my wires
BeatjunkieXL
Apr 3, 2012 01:14 AM
rdltmc3
Feb 17, 2012 07:36 PM
ericp1.8T
Oct 12, 2011 12:24 PM
kimi
Aug 7, 2008 10:04 PM
hxgaser
Apr 25, 2008 06:54 PM
