VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
what do i need for vagcom
Old Jan 22, 2009 | 08:08 PM
xxbmxlsxx's Avatar
Default what do i need for vagcom
i want to be able to scan and datalog my 2001 s4. what parts(cable and software) and where do i get them for the vagcom stuff?
Old Jan 22, 2009 | 09:59 PM
RED_01's Avatar
If you have a B5, the Key-USB is all you need.
Get the Ross-tech, all others are shareware versions and all the functions aren't available.
Old Jan 23, 2009 | 10:11 AM
xxbmxlsxx's Avatar
can u send me a link to the stuff i need? when i go on there im not sure what im looking at. and what is limmiwinks?
Old Jan 23, 2009 | 12:11 PM
cu52's Avatar
Get this: http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
Software is downloaded here: http://www.ross-tech.com/vag-com/download/
Or find someone on here that can scan for you. Make sure you ask them what their favorite beer is.....
http://www.vagtoolfinder.com/locator.aspx
Old Jan 23, 2009 | 12:32 PM
xxbmxlsxx's Avatar
its $250??
Old Jan 23, 2009 | 12:37 PM
xxbmxlsxx's Avatar
does that do everything i want to do?
Old Jan 23, 2009 | 12:38 PM
cu52's Avatar
Originally Posted by xxbmxlsxx
its $250??
Yes it is. The real cable allows you to use all aspects of the software as the activation is built into the cable not the software.
I found mine on eBay for $150 a year or two ago. There is one there now, but it is serial not USB if that works with the laptop you have.
Old Jan 23, 2009 | 05:27 PM
SourDieselS4's Avatar
The Vag-Com will let you check and clear codes and change some internal settings in the car. Im still learning with mine...
You can log with Vag but the more variables you record the lower the sample rate is. APR's ECU explorer is a very popular program for more advanced logging and minor tuning. I dont have this one but have thought about buying it, i think it still used your existing Vag cable
Old Jan 23, 2009 | 07:23 PM
RED_01's Avatar
The Explorer is also an awesome tool.
The faster sampling rates are useful for picking up minor glitches that the slower counterparts may not show you.
No mater whichever one you get, you won't be disappointed.
Just don't get the shareware Vag., it's garbage.
Plus once you get your car all squared away and running right, you can fine tune and do other fun stuff like trying to improve your FATS times.
rdltmc3
Feb 17, 2012 07:36 PM
ericp1.8T
Oct 12, 2011 12:24 PM
kimi
Aug 7, 2008 10:04 PM
Ericp501
May 13, 2008 06:14 PM
hxgaser
Apr 25, 2008 06:54 PM
