Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Buying tires off craigslist
Old Jul 3, 2011 | 01:27 AM
Tweev's Avatar
Default Buying tires off craigslist
Hey,
Cash is a bit tight right now and I'm due for new tires so I'm trying to find some off craigslist. I'm new to car ownership so I'm still trying to figure it all out.
I have an a3 with Continental 225/45 R17 94H on.
I saw a set of michelin pilot sport ps2 96Y 235/50zr17.
Would they work on my rims?
Thanks for your patience.
Old Jul 8, 2011 | 05:49 PM
Miles@TireRack.com's Avatar
They would likely work but are taller than your OE size so be prepared for your speedo to be off. It will appear that you are going slower than you actually are.
Old Jul 8, 2011 | 09:22 PM
warranty225cpe's Avatar
You MIGHT also run into problems with you AWD. Stick with the same size tires whenever possible.
Old Jul 13, 2011 | 07:48 PM
AWDaholic's Avatar
Senior Administrator
As long as all 4 are the same incorrect (albeit CLOSE to OEM) size, he sudn't have too much in the way of problems. THAT being said, I would do my level BEST to stick to an OE rolling diameter, as close as possible. According to THIS WEBSITE:
Tire size calculator
You will be 3mph off, at 60mph. That's enough to put you above the "grace" speed of most cops, at an indicated 75+ (where you will be pushing 80, actual).
There are MANY things to compromise on... I have learned, over the years, tires are NOT one of them.
soulstep
Sep 24, 2013 11:28 AM
audiSfour
Feb 25, 2012 10:16 PM
NickBroderick
Nov 23, 2009 12:13 PM
aj
Aug 20, 2007 08:47 AM
soccrstar
Mar 8, 2006 07:38 PM
