Wheels and Tires Post up threads with questions about wheels and tires for your Audi here
Too Many Blowouts. Advice on Change to Wheels & Tires
Old Jun 19, 2010 | 09:11 AM
tkny123's Avatar
Default Too Many Blowouts. Advice on Change to Wheels & Tires
I commute from Brooklyn to Connecticut every day, an hour each way. I have to drive over streets and highways that are in the worst condition in the US. My 07 A8L rides on Pirelli P6 P255/40 R19 100 V M+S tires on the 19" 12-spoke rims. In 3 years, I have had to buy 9 tires at about $300 each; had 4 blowouts (5 tires replaced, one time blew out 2 tires at once) and replaced 4 other tires bc the bubbles got real big. I always have bubbles in the sidewalls. I'm scared I'll be driving 85 mph one day, have a blowout and lose control.
I would appreciate ideas on the best solution to this problem. Some ideas I am kicking around.
1. Taller aspect ratio. If I get a 255/45 or 50, my sidewall height goes from current 4" to 4.5"-5". Do you think that extra bit of sidewall will significantly reduce the risk of bubbles and blowouts?
1A. I am assuming a 244/45-50 would fit into the wheel well. If it doesn’t, I would consider dropping to an 18” rim. That gets real expensive. May just have to live with the issue.
2. Run-flat tires, keep every other spec the same, assuming I can find one. Does anyone have runflats on their Audi? Does it really change the way it drives? Does it mess up the tire pressure monitoring system? Did you get a flat yet? Did they really run flat for a while?
Thanks in advance for your advice.
NYRangers
Feb 12, 2014 01:36 PM
bigatstyle
Nov 9, 2012 08:29 AM
aussie112
Oct 7, 2011 08:30 AM
d3m0nz3y3
Dec 10, 2007 11:19 PM
uros@
Aug 13, 2004 02:34 PM
