Sponsored by:
Sponsored by:
My heater doesn't work
Old 10-07-2007, 07:52 PM
Ezpanda's Avatar
Default My heater doesn't work
its a funny thing cause usually your a/c goes out before your heater does. Well anyways I bought my a4 used. and its a 2001 1.8t. I don't know what is wrong with my heater, my a/c works and my seat warmer works but my heater doesn't. Can someone help me out and tell me what I need to do to get it working? cause when I turn it on the first few seconds I can feel the heat and then it just turns cold. When I set the temp. at 65 it gets really cold and it shoots out full blast, when I set the temp at 85 or hi, it doesn't even get hot, it gets cold. So what am I supposed to do?
Old 10-07-2007, 08:09 PM
hiwords's Avatar
Default RE: My heater doesn't work
u either have air bubbles in ur coolant or a bad heater core. for the coolant, take the cap off and run the car for a little bit.
Old 10-07-2007, 08:10 PM
auditech79's Avatar
Your heater core is either blocked or the a/c control head is bad/temp flap motor is malfunctioning.
I would first try to remove the battery and un-hook the two lines to the heater core and use compressed air to blow out the heater core.
Old 10-07-2007, 08:14 PM
Ezpanda's Avatar
I ran my car with the coolant cap off and there are air bubbles in it. how much will that cost me to replace it, does warranty cover that? or do i have to pay for it out of my own pocket? I have extended warranty up to 200k. and where do i find the heater core in case the coolant isn't the problem?
thanks for your help guys
Old 10-07-2007, 08:16 PM
auditech79's Avatar
I would highly recommend trying to blow it out first before replacing it. The heater core could cost you some serious $$$$$ for removing the entire dash board.
Old 10-07-2007, 08:19 PM
Ezpanda's Avatar
so i unhook the battery and then there are two lines to unhook the heater core correct? and then what do i do? i'm sorry i'm very new at this, and this is my first audi. I'm used to hondas and acuras. this is something new for me. thanks again guys
Old 10-07-2007, 08:22 PM
auditech79's Avatar
Use an air gun with an air compressor and blow all the crap out of there. If you don't have one have a shop do it for you.
Old 10-07-2007, 08:26 PM
Ezpanda's Avatar
ok well i'm gonna try it tomorrow, cause i all my tools are at my cousin's house and he's not home, so i will let you know what happens after i try it. thanks until tomorrow. hahaha
jklingman
01-07-2012 12:41 AM
one4eyes
04-12-2010 01:05 PM
duderseb
09-09-2009 10:28 PM
DonStanleyA4
12-07-2008 09:55 AM
klinus19
01-11-2007 12:33 AM
Quick Reply: My heater doesn't work
