Heater doesn't work
Old Nov 24, 2008 | 10:31 AM
DonStanleyA4's Avatar
Default Heater doesn't work
My heater get a little warm but doest get warm enough. My thermostat is warming the engine up fine to the half point, Is it the heater core? or some valve?
Old Nov 28, 2008 | 03:31 AM
PHAHEEM's Avatar
I too am curious about this...anyone know a solution?
Old Nov 28, 2008 | 04:45 AM
CBenRieder600's Avatar
Sounds alot like a heater core but typically a blocked heater core will give off no heat. When you turn the fan to full power does it blow as much air as it use too? Also what have you done lately? A cooling flush or anything?
Old Nov 28, 2008 | 10:25 AM
I just bought the car. It is warm when the fan is al-away down but when i turn up the fan its cool. It had a new heater core put in last year and a new thermostat. Should i flush the coolant system? Or is it the climate control?
Old Nov 28, 2008 | 09:15 PM
mrelmo's Avatar
another 1 with no heat the core is not plugged, ac works good, defrost, floor and dash vents all work properly, what opens the heat door at the core, i think that is not operating
Old Nov 28, 2008 | 09:37 PM
S_R_N83's Avatar
I bet its the heater core. When mine was clogged, I got some heat at first then it would go away and be all cold. The hoses and everything were hot, just no heat was coming out.
Its expensive at the dealer. (Around $1000)
Don- I also had the heater core replaced a year ago from the dealer, and when it came to turn the heat on again when it got cold about a month ago there was no heat again. So, they replaced it again for free. Just FYI, so don't rule out the possibility that it could be the heater core again.
Old Dec 2, 2008 | 08:58 AM
sidespar's Avatar
Bleed your system. There is a bleeder hole on the heater core hose. Pull the hose back until the hole is exposed. Then unbolt the coolant tank and hold it as high as you can. Continue holding it there until coolant shoots out the hole in a STEADY stream without gurgling. Bolt the coolant tank back down and do the same thing using the bleeder screw on the front of the engine.
If this doesn't work, flush out your heater core by hooking a garden hose up to its input, then its output. And refill the system.
Old Dec 2, 2008 | 08:59 AM
sidespar's Avatar
you have an airpocket. see my reply above. I would be anything that if you put the car in neutral, then increase engine speed to 5000 RPM that the heat suddenly changes from cold to warm.
Old Dec 6, 2008 | 05:26 PM
RunMyA4's Avatar
Default Heat no working.
I just got my heater fixed. Previous owner used a product design to seal radiators from inside the cooling system and clogged the heater core. After a 1k got it fix. It could be a clogged heater core or control flap door stock.
Old Dec 7, 2008 | 09:55 AM
mrelmo's Avatar
at this point i think that it is a door "flap" not opening, however is there a seperate circulation pump for the heater core system thanks
jklingman
Jan 7, 2012 12:41 AM
one4eyes
Apr 12, 2010 01:05 PM
duderseb
Sep 9, 2009 10:28 PM
Ezpanda
Oct 7, 2007 08:26 PM
klinus19
Jan 11, 2007 12:33 AM
