Audi 100 no oil pressure
#21
I am trying to do this scan method from 12v.org
http://www.12v.org/maintenance/dtc.php
I just tried it and it will not produce anything... I may have to try the test light method.
Have you guys ever tried to get codes this way?
#22
I now have a VAG-COM so it has been a while since I used the blink code method but i have used it in the past. The trick is learning how to read it properly, the blinking is rather slow so have patience. And you will always get a 2111 error if the engine is not running because there is no engine speed sensor signal. I did not use a test light, I just used the check engine light.
Finnie1967
12-05-2012 02:45 AM
rustyleskiv
04-11-2006 01:15 AM
