Audi 100 no oil pressure
Old May 30, 2011 | 11:20 AM
  #21
kidislegit's Avatar
I am trying to do this scan method from 12v.org
http://www.12v.org/maintenance/dtc.php
I just tried it and it will not produce anything... I may have to try the test light method.
Have you guys ever tried to get codes this way?
Old May 30, 2011 | 11:37 AM
  #22
ManyAudis's Avatar
I now have a VAG-COM so it has been a while since I used the blink code method but i have used it in the past. The trick is learning how to read it properly, the blinking is rather slow so have patience. And you will always get a 2111 error if the engine is not running because there is no engine speed sensor signal. I did not use a test light, I just used the check engine light.
Old May 30, 2011 | 11:40 AM
  #23
kidislegit's Avatar
Yeah I could not get it to blink at all. I can start the car so I had it running and used a paperclip to short it. Hmmm I will have to try it again and see if it will produce something for me.
Old May 30, 2011 | 04:46 PM
  #24
kidislegit's Avatar
Question code 2141
I was able to get a code and it is 2141.. knock sensor control 1
Any suggestions how to proceed?
pdxrado
Jan 28, 2013 06:35 PM
Dallas09
Aug 30, 2011 05:57 PM
wrknkm
Oct 6, 2009 12:12 AM
rustyleskiv
Apr 11, 2006 01:15 AM
