clutch not engaging?
I was on a hill stopped and smoked the clutch getting back in to first. I drove maybe 80 ft to the gas station and filled up. When I went to leave the clutch no longer worked I limped it home in 1st. When I sit in the car before starting the motor I can shift it in every gear. When I crank the motor I can shift it no problem. Then it warms up and I cant get it into gear, its like there is a plate there blocking the path. I can turn the car off and immediately put it in first and crank her up again and she will move. What broke on me? I really need to get her on the road.
That is correct
Could be that the disk is dragging after the material warms up or your pilot bearing is grabbing the input shaft after it warms up. Really no way of telling without pulling the transmission down.
