need help how to drain coolant
guys need help on how to drain my radiator, haven't drained it yet when i bought it. been looking to audidiy and a4mods but cant find it.. there's lot of bolts there that looks like a drain plugs im scared to remove the wrong drain plug, any tips is highly appreciated. its a 99 a4 1.8t manual
thanks
thanks
Drain plug is located on the driver side, lower corner of the radiator. Turn counterclock wise to open the valve.
The lower radiator hose is on the passenger side on the bottom of the radiator. Lift up the metal clip and pull the hose out (the hose will take some force to come off).
I would pull the coolant sensor out that is in that lower hose before trying to pull the hose off.
