VAG-COM (*New* section) Need some help with a VAG-COM? Have some good advice to offer others using a VAG-COM?
VagCom- No Response from controller
Old Sep 19, 2009 | 05:06 PM
duderseb's Avatar
Originally Posted by BaconBait
Do you have an aftermarket radio? If so, disconnect your radio completely by disconnecting the wire harness. VAG-COM's are notorious for getting screwy when an aftermarket radio is involved.
No, my radio is stock... I can also access the HVAC Module... I've tried re-installing VagCom and this still happens...
This is perplexing... I really need your help guys, I've sifted through the forums but I cannot find a suitable answer for my problem...
Old Sep 19, 2009 | 05:11 PM
Pjbrof's Avatar
Have you tried it while the car is running instead of just 1st position?
Old Sep 19, 2009 | 05:23 PM
duderseb's Avatar
Yup, same problem... :-(
Old Sep 19, 2009 | 06:09 PM
ghost6303's Avatar
thats not a vagcom problem, its a problem with your car. the ABS module failing could interfere with the OBD port the same way an aftermarket ratio can. either unplug the module and see if you can scan again, or go to autozone and see if their generic scanner can see it.
Old Sep 19, 2009 | 06:32 PM
duderseb's Avatar
Any special precautions I should take before unplugging the ABS Module? (Like disconnecting the battery before I do it)? And my car is undriveable (Reason why I need to get into the ECU to find out) So I can't make it to autozone to see...
Old Sep 19, 2009 | 06:52 PM
duderseb's Avatar
YES!!! Issue solved, Ghost6303 was right... My ABS Module was conflicting with the ECU and would lock me out... All I had to do was unplug the ABSM and I got in like magic... Thank you very much!!!
Old Sep 19, 2009 | 08:23 PM
ghost6303's Avatar
glad it worked.
Old Feb 1, 2014 | 03:39 PM
  #18
hansesa's Avatar
Hi! what exactly did you do to fix this?
tbonetyler789
Jun 3, 2012 04:51 PM
99'A6
Jan 29, 2012 10:47 AM
ed2004tt
Mar 15, 2011 12:23 AM
hxgaser
Apr 25, 2008 06:54 PM
