Can this vac line cause bank 1 Lean?
Old Oct 10, 2008 | 04:36 PM
  #11
A4speed's Avatar
from your previous thread it sounds like your boosting fine. and if your 02 sensor is clean then onepoint8tee is right, u should replace your maf.
Old Oct 10, 2008 | 05:44 PM
  #12
Ultim8gamr's Avatar
the o2 sensor looked fine. no dark coloration. looked "dry" if thats a way to describe it. bought MAF cleaner today as one last chance of hope before ordering a new MAF. or is it bad to go used MAF?. ECS is showing new MAFs ($144.84)ncheaper than remans ($183.57). is there reasoning behind it?
Old Oct 10, 2008 | 05:47 PM
  #13
onepoint8tee's Avatar
MAF cleaner is a gimick. It's just glorified electronic parts cleaner. You can't magicaly fix a toasted maf element with a spray. The only time it would be useful is if you over oiled an intake filter and it caused your otherwise good maf to get fouled up. I wouldn't trust a used maf unless whoever is selling it offers a DOA (dead on arival) guarantee/return policy.
Old Oct 30, 2008 | 11:59 PM
  #14
Ultim8gamr's Avatar
so the final fix seemed to be a new MAF... also found the check valve above the airbox rotted. replaced that first to assess what really fixed the boost problem. just posting back for anyone else that runs into this problem to see the solution
Old Nov 4, 2008 | 12:47 PM
  #15
dubiousmusic's Avatar
can someone tell me what #4 indicates on the schematic on the first post?
Tadyswoows
Jan 2, 2010 07:07 PM
seana4
Oct 31, 2007 06:23 PM
vassar007
Jul 14, 2007 01:45 PM
turbo kraut
Nov 13, 2006 09:51 PM
gcain99
Aug 12, 2005 12:40 AM
