1993 Audi 100 CS Quattro V6 Bose Radio
Old Jan 3, 2007 | 02:35 AM
msa10's Avatar
Default 1993 Audi 100 CS Quattro V6 Bose Radio
Hi. I just replaced the battery on my '93 100 quattro v6. Afterwards the stock Bose radio/cassette playerwent to a SAFE mode and it will not play or do anything. Is there a way to "unlock"the radioor bypass it somehow? I am not the original owner, so if there is a code or something I never got it. Do I have any other option or should I take it to the dealer?
Thanks!
Old Jan 4, 2007 | 02:13 AM
kakarot's Avatar
Default RE: 1993 Audi 100 CS Quattro V6 Bose Radio
easiest thing is to try to google you model number radio online and try to find it.
what I did is I got a new radio.
Old Jan 4, 2007 | 05:03 AM
InExile's Avatar
the code might be int the car hidden somewhere ... glove box , center console, back of the radio unit, and dealer should be abe to hepl in worst case
Old Jan 8, 2007 | 04:06 AM
msa10's Avatar
Thanks for the suggestions. I don't seethe codeanywhere. I tried to remove the radio without success. DoI need some special tool? Its the original Bose radio/cassette unit. It has 4 small holes in the corners. I'm thinking that a special tool goes in there for removal.
Old Jan 8, 2007 | 06:04 AM
TommyL's Avatar
ORIGINAL: msa10
Im pretty sure you dont need any kind of special tool to remove it, because mine came out with just the screws. Cant remember if the bracket comes out with it though.
Did you disconnect everything from behind?
Old Jan 9, 2007 | 09:35 PM
InExile's Avatar
the 4 small holes might suggest the necessety of a special tool .. it looks like a U and it comes in pairs ... you could acctually stick some thicker wire in thhose holes and than see if the inside tabs come loose
http://www.crutchfield.com/S-U83vJ0L...;display=L#Tab
puremeerkat
Sep 14, 2013 07:54 PM
superaudi02
Jan 15, 2012 05:08 PM
jjul1495
Feb 10, 2011 09:13 PM
Aton
Sep 2, 2010 09:42 AM
asaucedo3
Aug 9, 2010 08:29 PM
