Audi 5000cs QT water leak inside
Old Jan 12, 2006 | 01:48 AM
cdc28685394's Avatar
Default Audi 5000cs QT water leak inside
Hey I have a 86 5000qt that has a water leak in the front. I noticed under the floor mats it was moldy and damp. Any thoughts as towhere I can look to fix it? My imediate thoughts would be the Sunroof drain but past that I'm clueless.
Thanks
CDC
Old Jan 12, 2006 | 08:24 PM
0fframp's Avatar
Default RE: Audi 5000cs QT water leak inside
Clean the leaves out of the area where the blower assembly is located. Also it could be your heater core if you are using Pentosin (blue colored) coolant.
Old Jan 12, 2006 | 10:55 PM
Thanks for the info. I will remove the the leaves. I know my heater does not work nor the AC. Where would I look to fix the heater. I am getting a Bently repair manual so with your input and the book I might be able to fix it.
dlaviga
Audi Q7
Nov 22, 2013 04:17 PM
madmatuk
Jul 16, 2013 05:17 PM
audi das
B7 Models
Aug 15, 2012 07:23 PM
j4n3k
May 5, 2007 01:28 PM
slee22
Oct 15, 2005 07:33 PM
