Water leak inside cabin
Old Aug 5, 2005 | 01:00 AM
slee22's Avatar
Default Water leak inside cabin
When it rains, I get a "puddle" on my driver-side floor. It drips from right above the hood latch-pull under the dash, and runs down the kick-panel. I can't tell where under the hood it's coming from, but the black trim piece at the base of the windshield is flat all the across.
Old Sep 10, 2005 | 09:19 PM
heisse_mkII's Avatar
Default RE: Water leak inside cabin
I'm having the same problem with my 00 but on the passenger side. Haven't found out where it is coming in from though.
Old Sep 11, 2005 | 01:37 AM
beefski's Avatar
it could be running down the inside of the door. from the roofline down
in the hinge area.
use a hose and try to duplicate
Old Sep 12, 2005 | 04:56 AM
karguy427's Avatar
You've got clogged cowl drains. Take plastic cowl panel cover off, find drains, Blow out with air hose.
Old Sep 19, 2005 | 02:23 PM
slee22's Avatar
I took the cowl cover off. but I found no drains. How many are there, and where do you find them?
Thanks.
Old Sep 30, 2005 | 08:09 AM
Ireland's Avatar
Theres one under the battery shelf. I hear theres another under the brake servo. You'll either have to shoot compressed air in under the battery (if your stuck) or do the proper job and remove the battery (1 bolt) and shelf (3 bolts) and there you'll find a bunch of leaves and garb stuffing up your drain hole. I usually get the garden hose and give the area a good wash out after clearing the drain, You'd be surprised how much stuff builds up in there even with the plastic liner fitted. I get this problem about 2-3 times a year (Well I do live in Ireland....rain,rain,rain!!)
The water that lodges in the 'battery compartment', once the level is right, tips up into your air filter box on your driver side and down into the blower fan and into the cabin.
Or you could have a leak in your windscreen, holefully not though.
K
Old Sep 30, 2005 | 12:16 PM
slee22's Avatar
Oh thanks for your help, now I can find them and clean them out. I found the leak though. On the roof there are two channels (near the doors) in the metal that go the length of the roof. Where the channel meets the windshield on the top driver side, there is supposed to be rubber sealant, but it's missing. So I filled it with some RTV and it worked (it rained last night).
Old Oct 2, 2005 | 06:31 AM
Mine turned out to be the water tray not being installed correctly. Stupid stealership.
Old Oct 15, 2005 | 04:02 AM
Oh never mind. It still leaks. It's coming through where the cabin air filter sits. It gets all wet too. Is there supposed to be a piece of weatherstripping on the back part of the tray?
Old Oct 15, 2005 | 07:33 PM
AndyChild's Avatar
I had the same problem on my 2000 A6 - it turned out to be a leaking windscreen just above the air filter. I carefully masked the entire lower section of the screen to plug the gap and applied mastic. It is now about 6 months later and the problem has not returned. The only problem now is that the car smells due to the carpet being damp for a long time.
Does anyone know where I can buy a replacement carpet without having to pay a ridiculous sum to the dealer?
RickA6
Sep 28, 2016 11:19 PM
madmatuk
Jul 16, 2013 05:17 PM
audi das
B7 Models
Aug 15, 2012 07:23 PM
j4n3k
May 5, 2007 01:28 PM
cdc28685394
Jan 12, 2006 10:55 PM
