Water Leak Inside my car
Old Aug 10, 2012 | 09:49 AM
audi das's Avatar
Default Water Leak Inside my car
2006 A4 2.0 Quattro
I recently changed the wiper transmission link. I thought I had put everything back in order and the wipers work fine. Recently we had some heavy rains overnight and i noticed a pool of water in the mat of the driver's side floorboard. The water seems to be dripping from underneath the dash above the pedals/under the steering column. Could my installation of the transmission link cause this or am I dealing with an entirely new problem? Any advice would be greatly appreciated.
This is what i followed:
Audi B6/B7 S4/A4 DIY: Slow Wipers Fix
Old Aug 13, 2012 | 06:30 AM
i_786_i's Avatar
Originally Posted by audi das
2006 A4 2.0 Quattro
Wet feet while driving, not ideal! - Russell Automotive Centre
Is this the same problem as what your having?
Old Aug 13, 2012 | 12:12 PM
audi das's Avatar
i 786 i Thanks for your input. It's greatly appreciated. I checked for any debris under the hood and didn't find anything. I flushed out the sunroof drainage line w/ an air compressor and a bunch of debris was cleared out from there. Would you happen to know if the plenim chamber drain holes empty out at the same release point as the sunroof's drainage?
Old Aug 14, 2012 | 10:53 AM
i_786_i's Avatar
Hi,
Sorry cant help you there, my car doesnt have a sunroof.
Old Aug 15, 2012 | 07:23 PM
Audi Tek's Avatar
Tech Certified
No it doesn't. The Plenum drain is under the battery
the windsheild deflector needs to secure tightly in the the groove of the windshield it directs most of the water away from the firewall.
leaves in the plenum is the most common water leak causes
madmatuk
Jul 16, 2013 05:17 PM
stevesa4
Jul 13, 2008 03:17 PM
j4n3k
May 5, 2007 01:28 PM
cdc28685394
Jan 12, 2006 10:55 PM
slee22
Oct 15, 2005 07:33 PM
