noisy valves
thank you; I found several manuals at Amazon for $112 and will pick one up there; after that I will look into repairing the noise; great car though, don't see many (any) around here in WNY; must say I look forward to the snow this year. David
Over the years I have tried all sorts of service manuals but Factory is always the best regardless of the make or model. Haynes is OK but Clymer and Chilton are totally useless.
I had what I though was a noisy lifter but it turned out to be a broken valve spring. Changing the lifters is not difficult but tedious. Make sure that your oiling system is in working order as low oil pressure can give clicking noise, especially if the head was reworked and one of the oil passages are blocked.
As far as I know there is no way to flush out the hydraulic lifters or the oiling system in any car, other than doing frequent oil changes every 500 miles. The idea being that you are using the added detergents in the oil at the maximum strength before they loose their strength. I certainly wouldn't use any aftermarket additives.
soccergk
Mar 1, 2008 02:13 PM
