noisy valves
Old Oct 17, 2004 | 02:44 PM
dcherrman's Avatar
Default noisy valves
Just bought a 90qc; previous owner had a valve job done; they are noisy; I have not purchased a manual yet (what is the best source?. Are these adjustable? Hydraulic? Any input is appreciated. David
Old Oct 17, 2004 | 05:33 PM
0fframp's Avatar
Default RE: noisy valves
The factory service manual (by Robert Bentley) is the best all others are not worth the frustration. The lifters are hydraulic.
Old Oct 17, 2004 | 09:40 PM
dcherrman's Avatar
thank you; I found several manuals at Amazon for $112 and will pick one up there; after that I will look into repairing the noise; great car though, don't see many (any) around here in WNY; must say I look forward to the snow this year. David
Old Oct 18, 2004 | 12:10 AM
0fframp's Avatar
Over the years I have tried all sorts of service manuals but Factory is always the best regardless of the make or model. Haynes is OK but Clymer and Chilton are totally useless.
I had what I though was a noisy lifter but it turned out to be a broken valve spring. Changing the lifters is not difficult but tedious. Make sure that your oiling system is in working order as low oil pressure can give clicking noise, especially if the head was reworked and one of the oil passages are blocked.
Old Oct 22, 2004 | 01:41 AM
xxlaudi's Avatar
Default is there an oil flush available?
I noticed the same thing with the Audi100 i picked up today? Is there an internal fcrancase flush that can be used? I was just planning to change the oil twice>??
Old Oct 23, 2004 | 01:35 AM
0fframp's Avatar
Default RE: is there an oil flush available?
As far as I know there is no way to flush out the hydraulic lifters or the oiling system in any car, other than doing frequent oil changes every 500 miles. The idea being that you are using the added detergents in the oil at the maximum strength before they loose their strength. I certainly wouldn't use any aftermarket additives.
soccergk
Mar 1, 2008 02:13 PM
XtremeR
Jun 15, 2007 01:47 PM
biddy
Apr 16, 2006 11:29 AM
Joeski
Jan 3, 2006 07:40 PM
Palfreen
Nov 11, 2005 06:52 PM
