Removing Belt/Belt Tensioner...
Trying to figure out how to get the tensioner off...
My old Jetta had a set of bolts that bolted the tensioner into the engine so it was stationary (after applying the right tension). The Audi doesn't seem to have any bolts... Do I just add pressure? Is there a special tool that I need??
Thanks.
Thanks.
Assuming that you are removing the alternator belt, if you have the old style tensioner, there is a octagon shaped slot in the arm of the tensioner. Into that fit a 10mm allen socket, if I remember correctly, and lever the arm to remove the tension on the belt. There is also a hole that you can fit a pin into (use a nail or something) to keep the tensioner in this position. Then loosen the center bolt and remove the arm and pully assembly.
markymarc
Feb 23, 2020 06:27 PM
jinsojoo
Oct 30, 2012 11:25 PM
jinsojoo
Oct 30, 2012 11:22 PM
