Allroad Model Line Audi's take on the modern "Crossover" of a sport utility vehicle and a station wagon
AR wont start Battery,Alternator or both?
Old Dec 6, 2008 | 03:25 PM
redhammer's Avatar
Default AR wont start Battery,Alternator or both?
It was crazy cold the night before , about 3 Farenheit. It wouldn't start so I ended up buying one of those portable starters,it strated right up. I drove it for 30 minutes, all seems ok.
Not it starts but I notice every time I turn on the light the battery gauge drops down or goes up when you turn the light on. It also goes up if you rev the engine.
I took some measurements with voltmeter:
car off: -11.70 and droping
car on idle: -13.80
car on idle light on -13.15
Obviously the battery is dead, but is the alternetor on the way out too. Shouldn't the voltage stay the same with a good alt. even when the battery is bad?
Thanks!
Old Dec 7, 2008 | 01:51 AM
yahoome's Avatar
Bad Battery - Maybe even frozen from not having a charge. Alt looks like it's doing what it should......
Old Dec 8, 2008 | 02:22 PM
redhammer's Avatar
Just put a new interstate battery today, with the car off it's reading -12.20 but the arrow on the voltmeter gauge still moves depending on if you turn the lights on or off between 12.5 and 13.5v. Is it normal or it's my Alternator. The old battery was titanium autocraft with a stamp 05/07.
Only one year old, too bad I don't have a receipt for it.
Old Dec 9, 2008 | 11:57 PM
auditech79's Avatar
You are testing the voltage with a multimeter at the battery and not using the dash voltmeter right? Don't trust the dash voltmeter, its never 100%. Test the voltage at the battery with the engine running, it should be around 13.8-14.0V's with no electrical loads.
Old Dec 11, 2008 | 12:25 PM
redhammer's Avatar
I'm using a voltmeter. Could it be a faulty gauge if it's constantly moving up and down?The arrow on the volt gauge is at 14v when I first start the car and once it warms up it's moving from 12.20-13.80, I hope it's not the alternator, not putting constant charge.
audia8a5
Jan 8, 2011 08:54 PM
jon.alvarez
Feb 3, 2010 10:29 PM
RedTX
Nov 9, 2007 12:01 PM
powersmokin
Aug 15, 2007 12:08 AM
MrGreen
Jan 24, 2007 04:34 PM
